Sign in to follow this
Followers 0
Monte Alban
Oven Sensor for GE jn970sbs1s
3 posts in this topic
My oven temps have not been accurate in some time.  I adjusted via the keypad but it did not correct the issue.
I have purchased two oven sensors from repairclinic.  One matched my model number and one looked just like the other.
I installed the cheaper of the two, and it still will not register an accurate temp even after adjusting via the keypad.
Question is:  will the sensor make a difference, even though they both have the same connector and length?
Wondering before I open the more expensive one for no reason.
Any advice is appreciated.
BTW, the old sensor registered around 700 ohms, well short of the suggested 1000.
Double check that model#.
(always) measure sensor readings at control board connection, not at sensor. This will show if there any bad connections between the two.
1 person likes this
Followers 0
