Problem with heating Jenn-Air WM30420W wall oven
25 replies to this topic
#21 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,195 posts
Posted 07 November 2013 - 05:48 AM
Pull the relay board and check the back/solder side of the board at all the relays and wire connection terminals.  Most likely just a burnt/bad solder joint on the relay.
William Burk (Willie)
Eureka, CA 95501
#22 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 November 2013 - 06:08 AM
Normally, I would agree, but that would usually affect the larger, current carrying connections.
She's saying she can hear the Relay clicking ON / OFF
#23 Budget Appliance Repair
  • 5,195 posts
Posted 07 November 2013 - 08:54 AM
Very common to hear exactly that, the relays are clicking - the relay load carrying contact points are open/closing but not carrying a load because usually will find solder joints melted/broken from bad/cold solder joints.
Eureka, CA 95501
#24 RegUS_PatOff
  • 33,588 posts
Posted 07 November 2013 - 11:25 AM
oh.. I though she meant the Relays were "clicking" ON / OFF, (fast)
when they should be staying ON
#25 Lisa Hund
Lisa Hund
  • 10 posts
  • Flavorite Brew:Good ol' Bud Light
Posted 07 November 2013 - 05:04 PM
Gentlemen, I don't see a way to upload a picture on here or I would show you what we found.  My husband took out the relay board to check for burned/broken solder points.  He found none, BUT what we did find was that the contact points for the bake relay were worn and carbon covered, and did not appear to be able to even make contact.  He cleaned them and bent the point to ensure better contact.  He put it back together and the oven is working normally.
I am ordering a new relay board, as this one is definitely on it's last leg.
Thank you for all of your help and suggestions!  You definitely led us to the solution.  So glad I did not buy a new control board!
Cheers, Slainte, bottoms up, and all of that!  If I could, I would buy you one!
#26 RegUS_PatOff
  • 33,588 posts
Posted 07 November 2013 - 07:52 PM
http://fixitnow.com/...urai-beer-fund/
http://www.repaircli...?R=154&N=905229
[img=]http://www.rcappliancepartsimages.com/dbImages/i/00001913/Relay-Board-74006612-00576512.jpg
