Sign in to follow this
Followers 0
dcoyusa
frigidaire gallery french door
4 posts in this topic
Is it normal for this type of Fridgidaire fridge (tec sheet #249389643) for the condenser fan not to run sometimes when the compressor is running. My guess would be the board, but when I go into diagnostic mode, the fan runs fine. I was wondering if this is normal, or a board problem.
Fridge model number ?
usaually they rip the mod# off, but I got lucky they crumpled up the stock control report and put it inside the fridge.
Mod#= FGHS2644KF
... Is it normal for this type of Fridgidaire fridge (tec sheet #249389643) for the condenser fan not to run sometimes when the compressor is running.
I can't find that tech sheet number ...
... Mod#= FGHS2644KF
IF the Fridge uses a standard Compressor, the Condenser Fan is wired together with it.
IF the Fridge uses a VCC (variable capacity compressor)
then the Condenser Fan could operate separatley
I found
FGHS2644KF0
tech sheet 241912901
FGHS2644KF1
tech sheet 240389638
FGHS2644KF2
tech sheet 240389641
FGHS2644KF3
Followers 0
