Need a door reversal procedure for Amana bottom freezer
4 replies to this topic
#1 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 04 November 2013 - 07:05 PM
Door reversal help for a bottom freezer model # ABC2037dps
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,787 posts
Posted 04 November 2013 - 07:35 PM
from the use and care manual https://www.dropbox.... - 12828152.pdf
Door Reversal
In some installations, reversing the door swing allows
for more convenient access to stored items. Both
doors can be reversed on freezer door models and the
fresh food door is reversible on freezer drawer models.
1. Remove door(s) (see page 4).
2. Transfer cabinet plugs and cabinet
screws to opposite side of cabinet.
• Remove cabinet plugs with flat
blade of screwdriver tip wrapped
in masking tape.
• Remove center mullion screws
with 5⁄16” hex head screwdriver
3. Transfer door stops from bottom edge of fresh food
door and freezer door, if applicable, to opposite
side of door edge.
• Use a Phillips screwdriver
for removal and installation.
4. Install handles (see below
and page 7).
5. Reinstall the door(s).
Handles
Remove and discard handle packaging and tape.
Handle design varies from refrigerator to refrigerator.
Please reference the appropriate instructions for your
model below.
Fresh Food Handles
Standard Front Mount Handle
Materials Needed:
• Phillips screwdriver
• 5⁄16” hex head driver
To Install:
1. Remove 1⁄4” hex head screws from
door face with hex head driver, and
Phillips screw from top of door.
• If reversing door, remove door
plugs from opposite side of door and insert in
screw holes.
2. Align handle holes with screw holes on
door face and secure with two door face
screws from step 1.
To avoid possible injury and damage to property:
• Place doors on a nonabrasive surface protected by
towels or rugs while working directly on doors.
CAUTION
Note: If not installed, the handle is located in the
interior of the fresh food section or attached to the
back of your refrigerator.
4. Ensure the door handle is snug to the
door panel.
To Remove:
Reverse installation procedure.
www.DurhamApplianceThrift.com
#3 jumptrout
jumptrout
  • 1,382 posts
Posted 05 November 2013 - 03:57 PM
Thank you for the info.
I already read that.
It does not apply to this fridge.
I figured it out.
A rubber hammer really helps to re,ove the side trim and handle.
It is also needed for replacing these parts.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,787 posts
Posted 06 November 2013 - 04:52 AM
If known beforehand, don't you think a good heads up like "i tried the info in the manual and it does not apply" would have been in order?
#5 jumptrout
jumptrout
  • 1,382 posts
Posted 06 November 2013 - 07:39 AM
I didn't try it.
I read the manual and no parts or procedure were the same as this unit.
I thought I had the wrong manual until it said,"this may not pertain to your refrigerator:.
That is when I made my post hoping for a model specific procedure.
I really do appreciate your time and effort.
Heck,if it had just noted, "a rubber mallet will help in door reversal" the light bulb may have gone off.
How to reverse the doors in an Amana bottom-mount refrigerator
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 05 November 2013 - 03:50 AM
Source: Need a door reversal procedure for Amana bottom freezer
Read Full Entry →
