Kenmore bottom freezer icemaker
5 replies to this topic
#1 timmydh
timmydh
  • 1 posts
Posted 04 November 2013 - 08:55 PM
My icemaker stopped working.
Flow tube is all clear & not frozen.  Water pressure is good.  Inlet valve tests OK.  Installed new icemaker and still no ice.  Tested icemaker with jump wire and nothing happens. Is it a power problem?
Wondering what to do next.  Could wire harness in icemaker be bad?  Used original when installing new icemaker.  Only other thing I can think of is the inlet valve but that seemed to test OK.
Appreciate any/all help.  Thanks.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,872 posts
Posted 04 November 2013 - 09:13 PM
Do a continuity check on the harness, particularly the wire with the white and black rectangular tbermal fuse. Then again I could be mistaken since you did not provide a model number.
btw, what are your freezer temps?
www.DurhamApplianceThrift.com
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 November 2013 - 09:17 PM
does this Fridge have a model number ?
#4 NCARepair
NCARepair
    Kohai
  • 339 posts
Posted 04 November 2013 - 10:43 PM
Possible bad door switch?
#5 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,047 posts
Posted 05 November 2013 - 07:10 AM
And if testing/jumping T-H on ice maker you must tape door switch shut or ice maker won't work on alot of bottom freezer units.
William Burk (Willie)
Eureka, CA 95501
#6 Applianceman97
Applianceman97
    "Hollywood"
  • 2,597 posts
Posted 05 November 2013 - 12:33 PM
Sounds like the harness to me.
