SHE6AP02UC/05 Bosch infuriating E:24 drain error
6 replies to this topic
#1 acadiel
acadiel
    Ikkō-ikki
  • Chief Appliantologist
  • 30 posts
Posted 05 November 2013 - 01:19 AM
Hey everyone -
I have a Bosch dishwasher showing the nice E:24 error (drain clogged).. been beating my head over this the past day or two.  It always throws it right after it does it's little self checks and tries to drain anything that might still be in the unit (in other words, after only a few minutes.)
* First, I took the drain out of the bottom of the sump and removed that white tab thing and made sure nothing was in the impeller, and that it could spin correctly.  Then (in front, after removing kickplate), I also took the hose out (after removing the clamp from on top of it) and looked at the other side of the impeller.  Looked good.
* Threw a couple quarts of water in before trying a new cycle; I hear it draining the water perfectly into the sink drain.
* Checked the sink drain it's connected to; it's working OK
* Held the > and DELAY, powered the unit on, pressed < once (P1 - test mode), and ran it a couple of times.  Always ends up with a 0 (no errors).  Unit fills, drains, everything - just fine.
I'm at a loss.  Thoughts?  This is driving me mad :)
Edited by acadiel, 05 November 2013 - 01:24 AM.
    Shōgun
  • Master Samurai Tech
  • 31,400 posts
Posted 05 November 2013 - 03:25 AM
Have you seen this topic?  http://appliantology...-i-vacuum-sump/
Has some info that may apply to your situation.
#3 acadiel
acadiel
    Ikkō-ikki
  • 30 posts
Posted 05 November 2013 - 10:07 PM
Thanks, Samurai -
I went ahead and ordered the drain pump from Repair Clinic.  I Googled around the stash and it looks like you just twist it counter clockwise after removing the wiring to remove it.  In the meantime, if I do the 20 minute or so Customer Test Program and get a 0 error code, I can get it to initiate a regular load right afterwards, so I'll keep doing that until that no longer works.
Thanks! :)
    Shōgun
  • 31,400 posts
Posted 06 November 2013 - 08:12 AM
Yep, bayonet style.  Piece of pie, tovarish!
#5 NCARepair
NCARepair
    Kohai
  • 341 posts
Posted 07 November 2013 - 09:38 PM
Try removing fine mesh filter from sump. These being plugged will cause drain error. Bosch part 645038
#6 acadiel
acadiel
    Ikkō-ikki
  • 30 posts
Posted 12 November 2013 - 06:29 PM
Just wanted to come back and say the RepairClinic pump fixed it! Thanks! Sent from my iPad using Tapatalk HD
    Shōgun
  • 31,400 posts
Posted 13 November 2013 - 08:55 AM
Thanks for the update!
