LG front load washer, no power
6 replies to this topic
#1 gsiebrecht
gsiebrecht
  • 4 posts
  • Flavorite Brew:newcastle
Posted 05 November 2013 - 09:13 PM
When I press the power button and the machine is plugged into a GFCI outlet, the GFCI trips.  When plugged into a standard breaker outlet, the washer will not power on at all; the breaker does not trip.
The red led light on the main circuit board will blink red when i hit the power button but will not stay lit.
No lights on the front panel.
I acquired a different circuit board off ebay and that board did not work either, no guarantees that board was any good either though; I only paid $50.
Is there a test I can do with a multimeter to narrow down the problem here?
The model number is wm2550hrca
thanks everyone
#2 john63
john63
    Dean of LG Appliantology
  • 2,223 posts
Posted 05 November 2013 - 11:52 PM
Remove the Top Cover of the washer.
Trace/follow the *plug* inside the washer---to the Electrical Noise Filter (6201EC1006L)
Pull off the *white* plug---use a test meter to check for 120V at the *white* plug (if no power---the fault is outside of the washer)
Re-connect the *white* plug back into the Noise Filter
Pull off the *pink* plug from the Noise Filter---test for 120V at the **Noise Filter** (NOT at the pink plug)
If no 120V at the Noise Filter---replace it.
If 120V is measured at the Noise Filter---replace the Main Board (EBR64144911)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 gsiebrecht
gsiebrecht
  • 4 posts
Posted 22 November 2013 - 07:57 PM
I replaced the circuit board, the red led light blinked, I heard a snap and still no power. There is power at the noise filter.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 November 2013 - 11:43 PM
Has this washer worked OK at this location up till now ?
#5 gsiebrecht
gsiebrecht
  • 4 posts
Posted 23 November 2013 - 10:40 AM
yep, here is an update, I was turning the tub by hand and I heard the machine beep, the machine was not plugged in. I then plugged the machine in, turned the tub by hand about 20 times and hit the power button; the damn thing turned on.  It's working now. I have no explanation.  The tub did not appear stuck and it turned freely.
#6 gsiebrecht
gsiebrecht
  • 4 posts
Posted 23 November 2013 - 03:26 PM
another update, I heard a scraping noise, took the tub apart and the heating element is burned out, several splits and char marks, it distorted enough to bend itself up and contact the tub. I imagine that is what was causing the ground fault.
    Shōgun
  • Master Samurai Tech
  • 31,221 posts
Posted 23 November 2013 - 05:01 PM
Good find!
Here's your replacement heating element:  http://www.repaircli...3121501/1377871
