Kaptain Kaos
Kenmore 110.22042100 - Won't Drain
13 posts in this topic
Found the tech sheet under the top panel - tech sheet part number is 8526175 - ran all the diagnostics with no error code.
Machine spins, fills, etc... does not drain.  Makes noise like it should be draining, no water leaves...
Help?
are the Drain Pump Hoses clogged ?
I've checked the hose on the back of the machine - I haven't gotten to fully removing the cover around the tub yet to look at the drain pump.
  Check the drain recirculation solenoid valve.
Eric
Eric
Ok - whereabouts would i find that?
Thanks!
  Mounted to inside back panel right where the drain hose exits the washer. Must be energized for drain. When de-energized, water is diverted back up to tub discharge funnel. The valve is covered by plastic splash protectors. You should be able to operate the valve by hand. When in drain mode, check for 120vac at 2-pin plug where solenoid plugs into harness wiring. If you have voltage but solenoid won't energize, replace valve. The solenoid is operated by DC current. Inside the solenoid "box", there is a diode bridge rectifier and fuse. There's two coils for the solenoid, one for pulling solenoid in and the other one is then switched in to reduce current for holding solenoid in position.
Eric
http://www.repairclinic.com/PartDetail/Drain-Valve/3358559/521215
Edited by fairbank56
No obvious blockage.  It doesn't look like I can operate the valve by hand - my guess is it's broke.
Not sure it's worth spending 78 bucks on a part for a twelve year old washing machine.
Is it possible to just bypass the thing?  Get it working for another few weeks...?
  Disconnect the diverter valve inlet hose (top hose that goes up behind tub), move drain hose over to where inlet hose was connected, don't use the Catalyst option.
Eric
Eric
Thanks - I'll give that a try this evening.
  Drain hose being the short jumper hose between valve and back of washer connection, not the one from the pump.
Eric
Well, that did the trick.  Ran through a full cycle with no issues - drained like a champ.
Thanks again for all the help!
