Samsung dryer dv218aew/xxa
tpoindexter
http://appliantology.org/files/file/660-samsung-dryer-timer-countdown-problem-service-bulletin/
Samsung Dryer Timer Countdown Problem Service Bulletin
Models: DV218AEB/XAA, DV218AEW/XAA,DV218AGB/XAA,DV218AGW/XAA
Symptom: In sensor dry cycle, the timer counts down to 6 minutes then adds 1:06 on the display.
Solution: Replace the Main PCB Assembly
Samsung Dryer Fast Track Manual DV203 - DV337
Models: DV203*** DV206*** DV218*** DV306*** DV317*** DV328*** DV3C6***
DV209*** DV219*** DV316*** DV326*** DV337***
Revision 4
