Dacor Single Oven MCS130S
3 replies to this topic
#1 jss_old
jss_old
    Ikkō-ikki
  • 25 posts
Posted 07 November 2013 - 09:55 PM
Broil element not working when broil selected and does not self-clean well.  Pulled grid and pushed red button on high temp thermostat to reset but no effect.  All other functions work fine.  Anything further I can do as a DIYer? Thx.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 November 2013 - 11:35 PM
... Broil element not working when broil selected
... and does not self-clean well.
1) may be a bad Broil Element OR a bad Oven Controller
2) :woot:
“My Rules”:
Rule #1) Don't ever use Self-Clean on any Oven.
Rule #2) If you're thinking about using Self-Clean, see rule #1.
That can wreak havoc on Electronic Controllers and Connections.
http://www.repaircli...R=154&N=1036110
http://www.repaircli...R=154&N=1012426
#3 jss_old
jss_old
    Ikkō-ikki
  • 25 posts
Posted 08 November 2013 - 05:44 AM
Is there a way to test these to determine if both or just one have malfunctioned? Is there a diagnostic program that can be run? Thx.
#4 RegUS_PatOff
  • 33,588 posts
Posted 08 November 2013 - 07:16 AM
Someone would need to test the Broil Element with an OHM meter,
OR a good visual inspection may notice that it is broken.
If it's not a bad Broil Element, then most likely, the Oven Controller is bad
