Troubleshoot modern appliances with confidence…
llky
GE PSS26MGPABB refrigerator not working
3 posts in this topic
Have a GE refrigerator model no.PSS26MGPABB that the only thing that is working is the lights and the controls in the fresh food section.The compressor and both the fans are not coming on.I'm thing that it's the main control board,what do you guys think?Is there a way to check this out?.Thanks for your time.
try unplugging the j2 connector and see if the compressor will fire up. If so, there is a fan problem.
Your fridge could also be stuck in defrost mode which would lead me to beleive you have a bad board. I don't think a bad defrost thermistor will keep a fridge in defrost as I think there is a fail safe but you can try and unplug the fridge, unplug the j1 connector and plug fridge back in.
Thanks for the help and suggestions I'll try what you suggested.Thanks again
