meyer2311
Frigidaire Beeps 3 times and frost on freezer back panel
3 posts in this topic
I have a Frigidaire refrigerator M# GLHS66EJBO side by side.  We had a power outage just over a week ago and the frig started beeping 3 time every now and again.  The display says that its set at 0 degrees in the freezer and 35 degrees in the frig. If i try to set a different temp it beeps 3 times and then shuts off and restarts.  If you try to turn the frig off by holding the on off button it turns off for a split second but turns right back on.  It cools ok but after a couple of days it starts to drop temperature and I have to unplug it for a few hours and then it works with the beeping and the non adjustable temp setting for a couple more days.  Also the lower panel in the freezer is frosting.
Please help!!!!!
Looks like your control board took a power spike......P/N 241739703...........Now P/N 241739711...................About 153 clam$ at repair clinic...........Access the defrost bi-metal / thermostat  at the evaporator coils and check the part for continuity.......Doubt  that part has failed but best to check before ordering parts..........looking thru the literature to see if your unit has a diagnostic mode...
