clecun
GE washer has no display
5 posts in this topic
My GE washer  model number WPGT9150HWW has no power on the display. There is power to the washer. When you unplug the unit you hear a click from the main circuit board. You can hit the power or any of the buttons and nothing happens ( no display). I can not find a fuse on this unit and all the connections look good. Any ideas?
I can't find a wiring diagram for this one that calls out the power supply voltages to the display board.  Absent that, the other way to play this is to replace the display board.  If that doesn't fix it, you can return the board for a refund:  Part number: AP4344456
Thank you. I found I had voltage to the main circuit board, but not sure which pins to check and at what voltage they should be. I already ordered the display board, and I saw that it shipped today. I will let you know if it does not work.
Chris
Already checked the fuse,  it was good. Just got my display board in today and got it hooked up, still no display. Must be from the main circuit board. Guess I will be ording one of those tonight.
