nate
Roper washer RAS7133RQ4, intermittent spinning
9 posts in this topic
I have been battling with my roper, RAS7133RQ4 washer for a week.  It will not spin in spin cycle, but I can hear the motor running.  I have replaced the clutch.  Removed the basket to ensure nothing was stuck or jammed.  I have double and triple checked the drive block and the motor coupling, which are both in perfect condition.  With the transmission removed, when the input shaft is moved the agitator shaft moves accordingly.  I have also checked the red wire in the motor wire harness, as I have read it is notorious for breaking in the harness.  It looks good as well.  Every time I tear it apart and put it back together, it works perfectly for one load.  Then it goes back to not spinning, but the motor is still running.  Last night after it stopped spinning again, I opened and shut the lid rapidly 5 or 6 times, and it suddenly broke loose and started spinning.  This morning on the next load after it stopped spinning, I got it started by unplugging, and then spinning it by hand a few times it started spinning again.  Needless to say, I am dumbfounded.  Thanks for any help you can offer.
Nate
  If you can spin the basket easily by hand, then your drive block is shot. The broken red wire is a problem with the new belt drive models, not your direct drive model. The washer should drain without spinning, then the motor must pause for a few seconds to release neutral drain, then starts again for spin. If motor is pausing as it should, run it in spin mode with cabinet removed and lid switch bypassed. Observe the clutch hub and the basket drive up inside the brake hub. If the clutch hub is spinning but basket drive is not, then the clutch is slipping or there's something wrong with the brake cam driver. If both clutch hub and basket drive are spinning, then your drive block is shot. If neither is spinning, turn washer off for a few seconds and then back on. If clutch hub is still not spinning, it's a gearcase problem.
Eric
Edited by fairbank56
2 people like this
I pulled the cover and bypassed the door switch.  The washer drains fine, and pauses after draining.  The washer agitates, but will not spin.  During spin cycle, the neither the clutch or the basket drive spin.  I turned the washer off and on again, and nothing happens, motor still runs with no spinning.  Sounds like I'm getting a new washer.  Thanks for your assistance!
Nate
  He said that he has already triple checked it.
Eric
Drive coupling looks new.  I wish that was all it was.  Thanks though.
  To be absolutely certain that the coupler is ok, rotate gearcase input shaft CW by hand. If the clutch hub doesn't rotate, it's the gearcase but it's odd that it has worked on occasion while you have worked on it. You might just want to open up the gearcase and take a look. They are repairable and parts are readily available. Could be a stripped spin gear or worn spin pawl. Cheap easy fixes. If you go this route, clamp the gearcase in a level position so you don't lose any oil and use putty knife to cut through the cover gasket material after removing cover bolts. Spin gear is the large plastic gear and is easily removed after removing the retaining ring.
Eric
Nate
This design of washer is better than any new ones currently on the market.  You are a good DIYer.  If you didn't want to repair, it would even be worth it to buy a new completely assembled transmission from repairclinic.com  (Rumor has it, you can even return installed parts if it doesn't fix your problem.)  Or maybe there is a good used one at your local appliance reseller!
2 people like this
The rumor is veritas!  http://www.repairclinic.com/Layer/Return-Policy
 Transmission part link:  http://www.repairclinic.com/PartDetail/Transmission/3360629/423
