Northern-Tech
Kenmore dryer / long drying cycle
17 posts in this topic
  Its been awhile since I have done any appliance repair, so Im checking for any pointers here. :woot: Customer said their Kenmore dryer c 1108476291     is taking too long to dry. Vent is clear.
Im thinking cycling thermostat,(  providing both elements are working fine. )  How do the moisture sensing strips come into play??  Couldn't find manual on the site either.....probably me rusty again....
As mentioned, I have been focusing on electrical for quite a few years, so im not as proficient  as techs that do this daily.              Thanks in advance!! :thanks:
I can't find a wiring diagram for that Canadian model
unless you have one you could scan & upload somewhere
Usually long drying times indicate a Vent problem
OR would need to know what temperature cycles of the air at the Dryer Vent
Usually about 135F to 160F with an empty load
Can't find this model number. Both elements???
  Should be 11 numbers in that model number?
Im having customer verify the model # for me.  Thx!!
Well, that's the model #. Hmmmmm? Well, will check elements, find print in console...( hopefully ), see how moisture sensors tie into circuit, and go from there.
Does the customer get the same results when using in timed dry as automatic cycles?  If so, the moisture sensors, wouldn't be in play here.
Any play in the blower wheel, i.e. stripped out)?  Door seals, sealing well?  What do(es) the heater(s) ohm out to?  Any lint built up in the vent screen area?  When you open the dryer up, how much lint build up do you find?
Also, the vent hose from the dryer to the wall.  How long is the dryer vent run?  How many 90* turns are there?  Vents should be 4 inch smooth walled, no longer than 25 feet subtract 5 feet for every 90 degree turn.
Edited by micabay
Is the Lint filter on top of the cabinet or inside of the door?  Or better yet, a good picture of the inside/outside of the machine may help determine a similar model#
Edited by micabay
Took a quick look when we were there, wiring a stove receptacle for him. Ducting is one 90 degree bend up, about 7 feet, then another 90 bend out the exhaust. I think ducting was ribbed. Elements were drawing 22 /23 amps. Lint screen was clear. Will further investigate in timed dry cycles and door seals.  :thanks:
Lint filter is on top.  Havent been back over there yet, customer is not in a big rush. Weather is not the best up here now. Was watching shingles flying off the building outside last night. Wicked wind!!
On your model number.............you have  M#  110.8476291......I could not find any thing................BUT If you change the 8 to a 6.....M # 110.6476291 , Does that one fit your model??????..........The first 5 numbers after the dot is the Sears stock number, most of the dryer stock numbers  that I found start with a 6.................Plus a smudged 6 could pass for an 8............
Hmmm, possibly. Im heading there tomorrow. Shall check this out....thx.
 I have some pics of the machine....but trying to figure out how to put on reply here........grrrrrr :confused:
OR upload pictures to some photo sharing site
then post link here
Click the "More Reply Options" button below the reply box.  You'll see additional options for attaching photos and much, much more!
post-5111-0-42747800-1385348501_thumb.jppost-5111-0-03394900-1385348518_thumb.jppost-5111-0-03394900-1385348518_thumb.jppost-5111-0-16384800-1385348532_thumb.jp
thanks for the tips on how to download pics. Photobucket was not the friendliest to use......
Here are 3 pics of the dryer, including the questionable model #.
thanks again!!
It's a Canada model, makes it harder to find info.
Here's the Sears Parts Direct website for Canada, it looks like you would input model number as: 110C8476291
http://www.searspartsdirect.com/partsdirect/brands-products/Sears-canada-Parts/Dryer-Parts
I don't know if the above will work or not, my computer really has problems with Sear Parts Direct websites.
