robertbird
whirlpool direct drive washer will not spin and makes loud scrapping sound
14 posts in this topic
Have direct drive whirlpool older model LSR 7233DQ0. Spin cycle stopped working. Agitator works, drains just fine.
replaced the Drive block and replaced the clutch and it did not change a thing. When the spin cycle starts it just make a loud scrapping womp  womp sound. If the agitator is working then the motor and gear box should be okay. What am I missing here. I have $100.00 into it already and am not inclined to keep putting money into it if i can't track this down
  Just because the agitator works, does not mean the gearcase is ok. Run washer in spin mode with cabinet off and lid switch bypassed. Observe the clutch hub and the basket drive up inside the brake hub. If clutch hub does not spin, the gearcase is faulty. If clutch hub spins but basket drive does not, then either the clutch is slipping or there's something wrong with the brake cam driver or the brakes are stuck.
Eric
I've had two of these this weeek.  Makes a horible noise on spin cycle but doesen't spin.  There is a gear on the agitator shaft and a plastic cam which releases the gear when it goes to spin.  This cam breaking was my problem.  Same symtom as you.  I had a couple transmissions in the shop and interchanged parts to reapair it.  If you have no spare parts then you need to order the transmission shapt that comes with the parts you need and replace your broken one.  Not an easy job if you have never done it.  Other option is to buy a new transmission.  Expensive!  Or shop around and find a good used one.  Good luck
maybe fairbanks can post a picture
... When the spin cycle starts it just make a loud scrapping womp  womp sound.
post YouTube video ?
I've seen the drive block do that also but you say you already changed that.  Sounds like the transmission to me.
1 person likes this
  The agitator cam is available alone, you don't need the whole shaft assembly however I don't believe this is your problem. This should not prevent the basket from spinning but may prevent the agitator from spinning with the basket or make a ratcheting noise if the agitator is partially engaging during spin as in this video. A fully engaged agitate gear would cause the agitator to go back and forth while basket is spinning but would not prevent basket from spinning unless it's full of clothes and they are against the agitator..
http://www.youtube.com/watch?v=MrzRW9jvM0A&feature=youtu.be
Eric
Edited by fairbank56
  The agitator cam is available alone, you don't need the whole shaft assembly however I don't believe this is your problem. This should not prevent the basket from spinning but may prevent the agitator from spinning with the basket or make a ratcheting noise if the agitator is partially engaging during spin as in this video. A fully engaged agitate gear would cause the agitator to go back and forth while basket is spinning but would not prevent basket from spinning.
Eric
that is true I can't remember if mine were trying to spin or not because it sounded so bad I just shut it off.  His symtums do sound like my trans problem.  We will narrow it down with a little more trouble shooting.  Let's hope it's something eles.   I think if the brake wasn't releasing it would be smoaking hot and probably spin a little too.  Work in progress!  Thanks Eric, now that you mention it I think the tub was trying to spin but the noise was like the washer was exploading.
I took off the outer panel so I could look at the clutch to see if it would spin when the control knob was on the spin cycle. The clutch is not moving or spinning  and all
I get is the loud grinding noise.. It agitates properly and drains properly but does not spin. Can I fix the transmission with the neutral drain pak kit.  I can buy a tranny on ebay for $100.00  I can fix just about anything should I buy the neutral drain pak kit  or just bite the bullet and get the tranny
  Open up the gearcase and take a look. Might be that the plastic spin gear is stripped, spin pawl on neutral drain plate may be damaged or spin pawl stud may have sheared off.
Eric
Pull the agitator and check to see if inner tub has rusted through. Have had two with this problem this month.
he said he replaced the drive block.  I'm sure he would have caught that, but thanks that  is always a good place to start.  It's sounding more like the neutral gear at this point.  Not to difficult to change.
found a used tranny for 80 dollars....will come tuesday.. I will install and let you know if I need to jump off a cliff if it does not work. This is almost as bad as working on vw passat. But I have to admit this washing machine is 15  years old  and all I have replaced is the rubber gears between the motor and tranny so I am not complaining at all.
The parts guy was talking about washing machines and said the top loading whirlpools are the best made and they have nothing but problems with the
front loader types
good advice but don't let it get around, those front loaders help us support ourselves.
1 person likes this
