applianceman97
Samsung dishwasher OE code
4 posts in this topic
Samsung dishwasher dmt800rhs getting an OE code. Fast track says overflow and leakage sensor can not drop below 3.5 vdc while filling. The manual does not give the info on what voltages the water level sensor should read. Im assuming since the other components test good it has to be the water level sensor. I would just like to know what the voltages should read. Any ideas? Or other possible causes of OE
Anyone?
Just to let you all know, the problem was what I suspected. Case sensor (water level sensor)
Good to know, applianceman!  Thanks for posting what you found-- this is sure to help others in the future.
Part link to the case water sensor assembly:  http://www.repairclinic.com/PartDetail/Sensor/DD9401006A/2310003
365-day Return Policy:  http://www.repairclinic.com/Layer/Return-Policy
