kzdun
No water comes into Maytag MVWC6EsWW1
20 posts in this topic
HI
I have a Maytag MVWC6EsWW1 that just stopped allowing water to come in.
Replace Washer Sensor Switch W10248240.
Check continuity on water input valve seleniods.
Screens on valve clean.
Suspect it may be the timer.
Is there anyway to check timer or is there anything else to check.
Thanks for any help.
  Does the washer spin if placed directly into spin mode?
Eric
Yep, spins, agitates.
Only when I put timer to allow water in, nothing happens.
  Agitates with no water in it?
yep.
By the way, many thanks for replying so quickly.
  The only place it should "dry agitate" is the last 2 minutes of wash in the heavy duty cycle. Does it agitate with no water in normal cycle?
I would have to put it back together to answer definitely.
But when I was putting it thru the cycles, I would hear it agitate.
I can't say for sure if it would agitate during the wash cycle.
Would that be helpful if I put it back together to verify.
I believe the answer is yes, but that was not one of the test that I did.
  So, you haven't checked to see if it will spin since the no fill problem occured? What do you have apart, control panel and/or cabinet removed?
Sorry, I mistook your question.
Yes it spins and agitates when I put it thru the cycles - wash, rinse.
I have the top panel off where the timer and Washer Sensor Switch is.
I took off the clamps to allow the back panel to come off far enough to test the
seleniods on the input valve.
Unplug pressure hose from sensor switch. Will it fill now? If no, does it still agitate dry? If yes, unplug 3 conductor plug from sensor switch, does it still agitate dry?
When you say "pressure hose from sensor switch", do you mean the transparent vacuum around 1/4 diameter?
I have to put it back in order to connect water line. Probably 15 min.
Will respond to your questions then.
 Yes, the clear hose.
Okay , I'm back.
Unplug pressure hose from sensor switch. Will it fill now? NO
If no, does it still agitate dry? YES
If yes, unplug 3 conductor plug from sensor switch, does it still agitate dry? YES
One of the 1st things I did.
I thank you for your time (and especially your sharing of your knowledge).
I can order the timer on-line for ~$63.00.
Hopefully, this will resolve the problem.
Again, thanks.
"bad Temperature Switch ?"
  The washer agitates with temp switch (load sense) unplugged!
... I missed that, I was thinking of the Flow Sensor was unplugged
Did you replace the timer with a new one or a "rebuilt" one?    Or have you even replaced it yet?...
At that price, it will be a rebuilt timer.  You pays your money, you takes your chances.  Rots o' ruck, GI!
  I think what he meant by "one of the 1st things I did" was that he blew through the pressure hose to make sure it was clear, not replace timer.
Eric
Edited by fairbank56
