417.98042701 kenmore dryer motor will not turn the drum
5 replies to this topic
#1 mlr
mlr
  • 2 posts
Posted 16 November 2013 - 07:18 PM
Commanding dryer on results in a humming noise from the motor and the drum will not rotate.  Motor becomes hot.  Drum, belt, motor shaft and pulley will rotate freely when turned manually by hand, hence nothing appears frozen.  Code 9E results.  9E not listed in document supplied with the unit.  Any idea what code 9E indicates.  Code E5b also was present.  Initial check indicated control thermistor was OK.  Appears the E5b may have been a result of the motor issue.  The electronic control unit appears to be functional as the motor is commanded on.    The unit is three years old, however, it has not been used extensively.  I would find it hard to believe that the motor is already bad.
#2 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 982 posts
  • Flavorite Brew:orange juice
Posted 16 November 2013 - 09:04 PM
take off the belt and take out the drum and try the motor.  If it hums, give it a spin by hand.  If it starts then it's a bad motor and if it doesn't start it's a bad motor.  Sounds to me like you have a bad motor.  They don't make them like they used to.
#3 Applianceman97
Applianceman97
    "Hollywood"
  • 2,396 posts
Posted 16 November 2013 - 09:50 PM
You can also test this without taking the drum out.
Hold the door switch in by hand. Have someone turn the start switch, while motor is humming turn the drum by hand to kick start the motor. Will do the same test that electro stated. To some degree. Just a little easier. But like stated above probably a bad motor. I would also take the front off the machine and make sure nothing is wedged in the blower wheel locking up the drum. ( keeping the motor from turning)
Edited by applianceman97, 16 November 2013 - 09:51 PM.
#4 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 982 posts
Posted 16 November 2013 - 10:05 PM
I think he said it turns freely by hand already.  Good tips on checking it easier.  In this case I'd have the dryer torn down in 5 min. after I'm there.  I forget it's a grasshopper sometimes.  Good call
#5 Applianceman97
Applianceman97
    "Hollywood"
  • 2,396 posts
Posted 16 November 2013 - 10:48 PM
Didn't see that he said it turned. Guess I need to read a little more carefully. Lol
#6 mlr
mlr
  • 2 posts
Posted 29 November 2013 - 11:38 PM
The dryer now works.  I had removed the connector to pin the wiring out and jostled the motor around.  At some point the internal switch became active after being stuck.  No definitive action but the machine does work again.
