ReliableApp
LG Washer Leaking Out Front A Little Bit WM2487HRM
3 posts in this topic
This is the second reported case so there has to be something to it.
Done so far:
-Cleaned glass and bellow
-Rotated spring placement from bottom to top
Still leaks a little bit...... :woot: ......
Many times, this is caused by a little chunk missing from the weep edge of the door boot. Even a little split in that weep edge is enough to cause a leak.
The weep edge is what I call that portion of the boot that contacts the door glass.
Thanks for the helpful info. The first one I saw was in great shape. Have not seen the second one yet. I'm curious if there are any service bulletins or other documented info from the members?
