GSD3300D35CC not pumping out completely
1 reply to this topic
#1 LLAMBERT
LLAMBERT
    Sōhei
  • Appliantologist
  • 147 posts
  • Flavorite Brew:Stone Ruination IPA
Posted 17 November 2013 - 12:01 PM
At end of cycle., 2 to 3 inches of water left behind. Pumps out when I am there, with force. Motor was extremely overheated, so I changed pump and motor assembly, same problem. I suspect an issue with the check ball but it seems ok. Any suggestions welcome.
Why? I came into this game for the action, the excitement. Go anywhere, travel light, get in, get out, wherever there's trouble, a man alone. Now they got the whole country sectioned off, you can't make a move without a form
    Shōgun
  • Master Samurai Tech
  • 30,574 posts
Posted 17 November 2013 - 03:08 PM
This training guide shows the correct placement of the check ball in these models with the "new" water distribution systems:  http://appliantology...training-guide/
Also, there was a service bulletin that addressed this problem, had to do with the connections on the cycle selector switches.  Let's see, what was that... oh, yes:  http://appliantology...rvice-bulletin/
You'll need to upgrade your membership to download the files.  If you're a professional Appliantologist, you should choose the Appliantologist package:  http://apprentice.appliantology.org/
