Bosch Range HDI7282U/07
4 replies to this topic
#1 Bingbing
Bingbing
  • 11 posts
  • Flavorite Brew:Samuel Smiths Taddy Porter
Posted 24 November 2013 - 09:09 AM
Sensei,
I have a gas stove top left front  burner that occasionally ignites (sparks) as the knob is turned. Lights fine with a match and I get a spark if the other knobs are turned.
The burner base and electrode are free of gunk, but the issue persists. I also filed the flame spreader.  The remaining three burners spark just fine and ignite normally as their corresponding knobs are turned.
I probably will need to replacing the spark harness and was looking for a Bosch service manual or instructions on removing the top and front panel. I understand the harness replacement is straight forward  once i have access. I have replaced the front  panel of a Jenn Air gas slide in downdraft range and believe the Bosch is similar.
Arigato
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 November 2013 - 11:25 AM
How's the Switch on that Burner Valve ?
#3 Bingbing
Bingbing
  • 11 posts
Posted 24 November 2013 - 12:48 PM
Thanks fo the reply. The gas portion of the valve is functioning. However, the electrical switch is only providing a burner spark about 10% of the time.
The other three burner switches work fine. It seems the switch might have gotten wet. I understande I would need to replace the harness. I was seeking clarification on removing the front panel and replacing the harness.
If there is an option to replace just the switch please let me know.
Regards
#4 telefunkenu47
telefunkenu47
    Kohai
  • Appliantologist
  • 406 posts
Posted 24 November 2013 - 07:40 PM
I just did one yesterday Front panel is held in place with 2 screws at right and left sides.remove back panel reach in from the back as your helper passes the wire harness through the opening in the front. Fish the replacement harness under the cooktop and reconnect wires to the spark mod and the main terminal block, red wire terminal. peice of cake.20-30 minutes tops.
Even root canal is easy...if you're a dentist...
#5 Bingbing
Bingbing
  • 11 posts
Posted 24 November 2013 - 08:24 PM
Thanks very much ! I'll give it a shot.
