LG Dishwasher LDF6920ST
3 replies to this topic
#1 jlb813
jlb813
    Sōhei
  • Chief Appliantologist
  • 215 posts
Posted 27 November 2013 - 06:40 PM
The customer reports that this dishwasher is not coming on and no lights are displayed. They have cut power at the breaker for 30 minutes and cut it back on with no change. First question is if I verify power to terminal WH3 would that verify the main PCB is bad? Second, if no power is present at WH-3 the noise filter is bad (assuming power is present at the power connections)? Lastly, if the noise filter is bad, and I bypass it, should the unit operate?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,968 posts
Posted 27 November 2013 - 06:47 PM
Also check for loose or burnt connections at the wire nuts where the dishwasher wiring connects to the house wiring inside the junction box in the bottom of the dishwasher.
Scott Wolf
#3 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 27 November 2013 - 09:23 PM
Yes---as Scott mentioned---check the power at the electrical/junction box to confirm power from the home/house circuit breaker.
Inspect the connections/wire caps (not loose or burnt).
If the power and wiring are "good"---pull off the *pink* plug from the Noise Filter---and test for voltage at the Noise Filter (not from the pink plug).
If "good" (110-120 volts at the Noise Filter)---the Main Board has failed.
If *no* power is at the Noise Filter---bypass the Noise Filter by "jumper-ing" the *white* and *pink* plugs.
Test Control Panel functions.
If the Control Panel "wakes up"---replace only the Noise Filter.
If the Control Panel remains "dead"---replace the Noise Filter and the Main Board.
Post the SERIAL NUMBER---this model has a *lot* of service bulletins and there's other service-related information to be aware of.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#4 jlb813
jlb813
    Sōhei
  • 215 posts
Posted 28 November 2013 - 09:18 AM
Thanks for the replies. I confirmed power at the junction box with no corrosion. No power was coming from the noise filter. After bypassing the filter, the unit did not wake up. The customer decided to replace the dishwasher. Thanks for all of the help.
