szkarlr
Kenmore DW seal won't stay put
8 posts in this topic
It doesn't leak, but the seal on the Kenmore Elite DW keeps sticking to the door so that when the door is opened after a cycle the seal is partially pulled out. Annoying. Does the seal just need to be replaced, or is something else going on? The DW is only about 10 months old so it doesn't seem like the seal should be shot yet, eh? Thanks, Karl
model number ?
The model number is 665.13964K015 from the plate on the washer.  (The manual just lists 665.1396)...thx
Are you talking about the gasket pushed into the channel around perimeter of the d/w cabinet:  http://www.repairclinic.com/PartDetail/Gasket/W10300924/1875876
Or the squared-off cabinet seal:  http://www.repairclinic.com/PartDetail/Door-Seal/W10179427/1546660
Post a photo or three if you're not sure.  Use an online image host and post the links here.
Is the dishwasher leaking?
Well, this would be the gasket pushed into the channel around perimeter of the d/w cabinet...thanks much!
If you want it done right, buy the new gasket and install yourself. If you want it done cheaper, call and see if you are covered under warenty.
