Kenmore 795.71019010 frost forming on evap. fan cover
7 replies to this topic
#1 nbapeman
nbapeman
  • 18 posts
  • Flavorite Brew:jumbo top-shelf margarita/sailor jerry & coke and ultimately Ten Cane on cubes
Posted 03 December 2013 - 09:24 PM
Frost forms only on fan motor cover.  Sears servicer told the lady to just knock the frost off with a wooden spoon.  He said it was suppose to be that way.  I don't think so.
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,953 posts
Posted 03 December 2013 - 09:46 PM
The So called Sears technician needs to be knocked on the head with a wooden spoon.
This unit was built by LG.  THe tech should have called "STAC"  (Sears Technical Assistance Center) to see if there are any service bulletins on this problem.
Check for good door seals and that the doors close tightly.   Check that the evaporator fan in the freezer runs okay. Remove the evaporator cover in the freezer and check the evaporator and see if the frost is in one spot or on the whole evaporator.
Scott Wolf
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,748 posts
Posted 04 December 2013 - 02:25 AM
Absolutely amazing. How much did it cost to recieve such highly technical advice?
Edited by DurhamAppliance, 04 December 2013 - 02:27 AM.
www.DurhamApplianceThrift.com
#4 Applianceman97
Applianceman97
    "Hollywood"
  • 2,461 posts
Posted 04 December 2013 - 02:38 PM
He must have been ready to get home. Must have been 1pm.
#5 PDuff
PDuff
  • 2,059 posts
Posted 04 December 2013 - 03:34 PM
Provided no warm air intrusion and the auto damper in the fresh food section multi-duct is working properly (nothing freezing in the crispers), could be an air flow issue caused by the evaporator fan motor, Main PCB, or both.
Note for tool bag:  Pick up that Craftsman Wooden Spoon.  (Available only at Sears)
    Shōgun
  • Master Samurai Tech
  • 30,543 posts
Posted 04 December 2013 - 06:00 PM
Calling now to reserve one...   :answer:
#7 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 04 December 2013 - 09:14 PM
Appears to be built 2011
I am *not* privy to Sears/Kenmore servicer information but...
This LG-built 3 door model---has had known issues (in 2011)
Most likely needs...
MAIN BOARD: EBR52304408
GRILLEFAN ASSY (cannot find correct part number)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
    Shōgun
  • 30,543 posts
Posted 04 December 2013 - 09:16 PM
Domo for the info-sist, Brother john!
