Skinnerback
Samsung Washer 3E error
2 posts in this topic
I have a Samsung top load washer, Model# WA422PRHDWR.  I recently started getting 3E errors occasionally shortly after starting a wash cycle.  The manual says the error means the motor isn't working properly, Samsung's website says it means a motor or hall sensor error.  I'm assuming the first step would be to try replacing the hall sensor, but wondering if anyone has any other thoughts or advice.  Thanks in advance for your help.
Ahh, the infamous Samsung top loader. I gotta tell ya, pilgrim, I hate these HE top loaders. Every last one of 'em, regardless of brand or model. Top loaders just don't do nearly as good a job washing the clothes in an HE (meaning low water use) environment as the front loaders do. But people buy them usually because they're cheaper than front loaders. But they're all finnicky and cheaply made.
Okay, off the soap box now.
First thing to do with any appliance that has an electronic control, especially Samsungs, is to talk to the control and retrieve the error code history. The last five will be stored there. You'll need the fasttrack manual to do this and I don't have one for this model, made one of the other Brethren can provide.
These Samsung toploaders are famous for wire harness problems. Start by checking and/or replacing the wiring harness, P/N DC93-00312B
