  • Announcements
steenblock
wfw9550ww00 powers up but only beeps when pushing thew start button
12 posts in this topic
OK...meaning your controls all light up nice and pretty but when you push the start button it only beeps?
yes
You must be getting an error code...check user manual for info.
the cycle lights all come up  and time left for cycle ----but no fault codes
Did this happen in mid-cycle?
Well-known problem.  The beeping is the giveaway.  Usually a bad MCU.  Do this test:
If the washer ACTS like it wants to start (but it obviously can't because the MCU is disconnected), then the MCU is loading down the CCU.  Replace the MCU:  http://www.repairclinic.com/PartDetail/Motor-Control-Board/W10384846/2024625
New one on me, thanks!
check door switch, make sure its sensing door closed
i tried pulling the wireyou indicated on the MCU but unit does same thing it did
Did you check the door latch assembly as Sublime Master sh2 suggested? See the tech sheet for details.
Will try that....you explained what to do a little more...thanks
