  • Announcements
Patricio
GE Washer WHDSR109J5WW
11 posts in this topic
Doing a dryer repair when customer asked to look at washer that was not spin drying clothes completely.   The tub seemed out of balance when spinning.  The lid switch sounded funny when I put magnet on it & would not complete circuit unless I put lid down.
Motor is not an inverter motor, it has a capacitor & has a 115Vac rating.  One speed motor according to repair clinic's replacement.   It has a transmission also.
When tub spins empty it seems out of balance, customer does not know if goes out of balance.  When I had it in spin cycle the tub stopped spin engaging the brake a couple of time seen seemed to spin full speed.   Because of time constraint (other calls) I did not have time to explore further (customer was not prepared to pay for more work).  Will schedule for another time.
I am thinking that the lid switch is failing. Timer is counting down while tub is not spinning I think, therefore loads are not completely spun dry.  The out of balance scenario everything seems OK as far as suspension goes.
Could be lid switch. Customer needs to pay for diagnosis. You may end up digging in farther than that.
Not to make fun, Patricio, but repeat this in other words if you can, please. I think it is critical to diagnosis.
The tub would start spinning.  Then completely stop suddenly like when ya lift the lid.  Brake engaged (it does have a brake does it not).  As fast as it stopped it started again then suddenly stop.    Again  then it spun full speed.  Kinda like when someone tries to learn the clutch of a standard car transmission.    Go ..Stop..Go   Stop   then go.
The reason I say lid switch is when I applied my magnet (which has worked on all other GE's)  the Lid switch would not close but instead feel like something moved in the switch if that makes since.
I did not give a diagnoses to this repeat customer.  I know I will be asked to repair in near future, want my ducks lined up.   Did I mention it has a mechanical timer,   it does not have a diagnostic procedure in the tech sheet.
I saw it had a manual timer. I would take a lid switch just like you thought.
Not a whole lot else it could be. Did all the other functions work okay?
There are some GE lid switches that require a horseshoe magnet or two separate magnets. They do have a moving piece in them that makes a noise when you use a magnet on them.
I think it is the switch, I have one in stock on the truck.   Not many functions on this machine.  Water level & three cycle timer. Everything seemed to work, just seemed to out of balance & the stop & go in the spin cycle.
I did get it to work with 2 magnets,   but I only fiddled with it a little while i was letting the dryer run to confirm dryer repair.  I heard & felt the movement in the switch, that is good to know about the switch.  Learning something or two everyday.
Edited by Patricio
Most GEs also have a balancing ring at the top of the tub. You should hear the fluid in it slosh when you rock the tub back and forth.
Make sure the pump isn't partially clogged and doing a slow drain.
If all the water isn't drained and these machines start to spin it will force the water into the water level pressure bell on the side of tub which trips the pressure switch back to full status which immediately stops the spin, spins stops pressure drops and it tries to spin again.
So noted Budget Appliance Repair & Olyteddy
Oh, man. That is just downright insidious.
