Tomme Tysdal
Maytag Washer MAV2755AWW Noise
6 posts in this topic
My washer makes this loud rubbing sound during agitation.
Here is the YouTube so you can hear it. http://youtu.be/Q0c_aRRbKHQ
  I don't get it. The pulley does not go back and forth during agitation. If it's making a noise during agitation, show video during agitation.
Eric
Sorry that was the only way I could duplicate manually. Here it with a light load. Doesn't make the noise with no load.
http://youtu.be/QHpBo254AeE
Thanks. What is this communist garb that I need a special tool? Any way around that?
  Brake rotor is under 200lbs of pressure via brake spring. Special tool required to release. Workaround is to remove two of the stator screws and replace them with 1 1/2" long 10-24 screws. Then remove all other stator screws and then slowly back out the 10-24 screws to slowly release the spring.
Eric
2 people like this
