Sign in to follow this
Followers 0
tstebbins
Samsung washer drain pump falling apart
5 posts in this topic
Have a 1 year old samsung washer  model WA456DRHDWR/AA    Serial Y0IX54EC701863Y, this is a top load washer The drain pump fell completely off pulled the hose loose from the tub flooded house, the housing had just worn away from the vibration. ordered replacement drain pump asm and installed. Guess what about 3 months go by and flood again. On to third pump this one lasted a bit longer but same end result. Any advice would be appreciated
I think they may have had a service tip about this. I remember hearing about it at ASTI last year. Let me check my list of tips and I will get back to you.
there is a service tip but it is just to install the same shitty part, when i replace then i put on a worm clamp so when it breaks again it hopefully dosent flood house.  FYI no need to replace entire pump assy, the sell the bracket the holds the pump on
I remember they at ASTI say something about the pump actually hitting the floor. That was causing it to break. ( I very well could have dreamed this as well)
Just wanted to thank you for looking at that, Wish they would come up with a better fix though.
Followers 0
