sco5678
Kenmore Washing machine Error code Sd
20 posts in this topic
I have a Kenmore Oasis Elite Model 110.28032700. I try and run a cycle and get a Sd error code almost at the end of cycle and the clothes are still very wet. I have tried to run drain and spin and get the same error code and clothes still soaking wet. I took apart the top of the washer and found 2 socks by the drain pump and thought that was the issue, so I ran a test drain and spin cycle and it was fine, put clothes back in and error code came back. Ran a full cycle with a few pieces of clothes and still got the error code and clothes still soaking wet.
Thanks for all your help
Are you using HE detergent? Too much detergent? SD is a sudsing error.
You shouldn't be using over 2 tablespoon. Some detergent manufacturers will mislead you to use more than you should.
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
Edited by tpoindexter
You mean you don't fill to the line in the machine dispenser???
This is what I hear from many customers. The answer is no. Brother T is correct. He speaks the truth!!!
Run washer through a rinse drain cycle. Then run it through a normal cycle with garments but without adding detergent. This should clear out all detergents.
If that fails:
You need to tip it back against the wall, disconnect hose from pump and check the pump and hoses for obstructions. If you got a shop vac it'll come in hand for the water when your taking. the lines loose.
If your still having problems post results and there's some more steps we can look at doing.
If you find excess suds in machine while running an empty cycle, fabric softener will kill suds. Put a little directly in the tub while running.
I am using HE detergent, so far I ran 2 cycles with no clothes and had no problems I added a few small towels (no soap) ran a cycle and got loads of suds, the error code and towels still wet. Going to try adding fabric softener and hope for the best.
drive shaft splines may be stripped at the basket hub, i have seen that numerous times.
that makes alot of sense with the error only occurring with a load.
Ok I have used fabric softener and no longer have any suds but again when I add clothes I get the same error code. So my next step sounds like checking the basket hub, it has been going off balance a lot before this Sd error code. My only question now would be do the stripped splines keep the clothes from spinning out?
Thanks agian
yes they would
I have ordered the basket drive hub kit should be here Saturday will post follow up after installed hope this is the problem.
Could it be that the towels are loaded with detergent? I have seen this one before.
when replacing the hub kit make sure the splines on the metal drive shaft are in good shape, i have seen the metal disintegrate away.
Thanks for the tip sh2sh2 I will check the drive shaft for that. @telefunkenu47 I don't think the towels are because I used fabric softener and there is no more suds but I will run another cycle to be sure.
Ok I have replaced the bearing hub which the old one looked ok but I replaced it any way and the splines on the drive shaft are good, did the test run and drain and spin sd error code and when I did a full cycle about 30 min into the cycle the water level filled up to the top I pressed stop to drain the water out of the tub and there was a ul error code. So I think I have to call someone in to fix the washer.
Grab the inside of the tub and pull up. The tub should lift up to the tub cover. This is a free floating tub. It acts like it's stuck. Make sure it moves up and down freely.
Did you do the check for obstructions mentioned below?
OK follow up, repair man came and he checked the drain flow and said it was fine, then he said the main control board was shot so he replaced it with a new one, he then left and I started having the same problem again after one wash, he came back 3 days later and said it must be the drain pump not draining all the water, so he had a new one and he replaced it when he took the old one off the fins where worn down and it was not pumping strong enough so that was the problem.
Thank you everyone for your help
Jon
So he refunded you the cost of the board?? right?
