Kitchen Aid Dishwasher KUDP01FLSS6
10 replies to this topic
#1 Applianceman97
Applianceman97
    "Hollywood"
  • 2,500 posts
Posted 20 December 2013 - 12:51 PM
Kitchen Aid dishwasher KUDP01FLSS6. Door cables keep breaking. I am replacing with the upgraded kit 8194001. I cant figure out why these keep breaking. Any ideas?
#2 Thirstytech
Thirstytech
    Kohai
  • 498 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted 20 December 2013 - 02:56 PM
Are they breaking in the same spot every time?
Does the door move smoothly after you put the new link/roller kit in or is it kind of stiff?
Nearly every house in the USA has at least 4 major appliances that will need repair, learn how this can work to your advantage -> http://www.mastersam...iliate.php?id=6
#3 Applianceman97
Applianceman97
    "Hollywood"
  • 2,500 posts
Posted 20 December 2013 - 03:22 PM
Not sure if they are breaking in the spot. And yes door is smooth after install.
    Shōgun
  • Master Samurai Tech
  • 30,580 posts
Posted 20 December 2013 - 03:48 PM
How frequently are they breaking?  When was the last time you installed the kit on this unit?
#5 Applianceman97
Applianceman97
    "Hollywood"
  • 2,500 posts
Posted 20 December 2013 - 04:07 PM
First one took 2 months to break. 2nd set broke in 2 weeks.
#6 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • 1,040 posts
Posted 20 December 2013 - 04:39 PM
Either they're not getting installed right, rubbing up against something or there is a custom panel that is too heavy. Make sure you install the whole kit not just part of it. Then adjust where the roller is so that the door stays wherever you leave it at when you open it.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#7 Applianceman97
Applianceman97
    "Hollywood"
  • 2,500 posts
Posted 20 December 2013 - 04:58 PM
I will double check my install. Maybe I missed something. I have changed a ton of these so I'm sure that's not it but everyone makes mistakes. There is no custom panel. Thanks for the ideas everyone!
#8 -Mike-
-Mike-
    Kohai
  • Appliantologist
  • 338 posts
  • Flavorite Brew:diet Pepsi
Posted 20 December 2013 - 08:34 PM
If you've got the updated rollers on there it has to be rubbing on something.
#9 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,026 posts
Posted 21 December 2013 - 07:42 AM
I just did a new one the other day, it was only about two years old, (I've never seen any go out that soon - this one even had the newer actual roller instead of fixed slide pulley).  Found they had some help from little critters!
Did you inspect for mouse droppings under dishwasher!
William Burk (Willie)
Eureka, CA 95501
#10 Applianceman97
Applianceman97
    "Hollywood"
  • 2,500 posts
Posted 08 January 2014 - 09:33 PM
So after going back again I found the problem. The left cable was hooking on the bottom access cover when the door is shutting. It was just removing itself from the hinge. Had to do a little creative modifications but it's all fixed up! Thanks guys.
    Shōgun
  • 30,580 posts
Posted 09 January 2014 - 01:24 AM
Good slam, applianceman!
