  • Announcements
LG Top-Load Washer WT4801CW: DOA and lid lock stuck
7 posts in this topic
Went out on this one yesterday.  Complaint:  DOA and lid lock stuck locked, holding clothes hostage.  Raised the top and tugged the lid lock string to liberate the clothes.  The more vexing problem is the DOA.
I went there with a noise filter, expecting it to be bad.  Sho nuff, it was.  Replaced it and now getting power to the main PCB but still no lights on the control panel, no action.  Only action is now when you press the power button, you hear a relay click on the main PCB.
Also, the LED on the main PCB is not lit.
I neglected to check for 5vdc between the main PCB and the display board.
Questions:
- Is the LED on the main PCB used as a self test/all-okay signal like on the Whirlpool VMW machines?  If so, is the fact that the LED was out a conclusive indication that the main PCB is bad?
- How diagnostically important is the 5vdc test between the main PCB and the display board?
- The fact that the noise filter AND something else (possibly the main PCB or maybe  the display board) are bad bothers me.  It's unusual for two parts to fail at the same time.  Does this indicate that something else fried and took these boards out:  door lock, drain pump, etc?
Thanks for any tips!
There's a Service Bulletin for this symptom (No Power) on LG WT4801 washers.
Check the MAIN BOARD part number.
The original (flawed) Main Board is part number (EBR73248501)
The revised/corrected Main Board is (EBR75131701)
The Service Bulletin is vague on details (cause of the "dead pcb")
Personally---I think I've only encountered this issue---2 or 3 times (in my neck of the woods).
<<<Is the LED on the main PCB used as a self test/all-okay signal like on the Whirlpool VMW machines?  If so, is the fact that the LED was out a conclusive indication that the main PCB is bad?>>>
The Main Board LED *does* indicate that there's power coming to it---from the Noise Filter.
It does not however---provide any useful "clue" as to any other potential issue/failure---of components on the M/B itself (or software glitches).
<<<How diagnostically important is the 5vdc test between the main PCB and the display board?>>>
It's not a test that I find myself doing very often---unless I *think* that Main Board is *good* and I want to verify power-to-the-Display-Board from the Main Board (percentage-wise the Main Board is the culprit).
<<<Does this indicate that something else fried and took these boards out:  door lock, drain pump, etc?>>>
Fortunately---the electronics on this washer---are not hyper-sensitive---when other components fail (such as Drain Motor/Lid Lock Assy)---as is the case on the Whirlpool-built VMW washer design.
Awesome, John!  Thanks as always for the excellent info!
Wish I had known about the service bulletin-- I mighta saved a handful of hair from scratching my head so much.
Sounds like I may have gotten lucky on this one.  I went ahead and ordered a main PCB from RepairClinic yesterday with FedEx 2-day delivery, hoping I could get it fixed for them before Christmas Day.  I had no idea about the part number change but RepairClinic apparently did-- when I looked up the part by model number, it already subbed over to the new part number you listed!
Thanks again!
I'll update after I install the new board.  Keep hope alive!
Success! Brother John was right on the money, as usual. The replacement main PCB came in tonight at 7:20PM. I jumped into The Guru Mobile, sped down to the customer's house and had her running in half an hour. Would have been less but I made a movie about it. Wanna see it? Here it is:
The customer was extremely grateful to have her washer fixed before Christmas. And I'm grateful for Brother John's reassurance that the main PCB was the only other problem besides the noise filter.
Just to recap, here are the two boards I replaced to fix this washer:
Noise Filter: http://www.repairclinic.com/PartDetail/Noise-Filter/6201EC2002J/2448672
Main PCB: http://www.repairclinic.com/PartDetail/Control-Board/EBR75131701/2630177
Merry Christmas to all!
Can you bypass the noise filter and apply direct 120 to pcb to check it?
<<<Can you bypass the noise filter and apply direct 120 to pcb to check it?>>>
Yes.
Great job & video Samurai :)
From the look of the tub and the nozzles (that direct water to the Dispenser Assy)---this washer will likely soon need a Water Valve Assy (iron?)
Merry Christmas !
Edited by john63
Great question!  That would have been a good troubleshooting / problem isolation technique that would not have risked a new noise filter board.  I'll add that in the next video.  Stay tuned!
