Sign in to follow this
Followers 0
rsg2000
GE CSS25USWC SS with Ice Maker CAN17 Not Dispensing Ice
8 posts in this topic
I have a side by side GE CSS25USWC SS with Ice Maker model CAN17.  The ice maker is making ice normally but the unit will not dispense ice from the door.  The motor is running when the lever is depressed and I can see the metal drive auger spinning when I open the door and the bucket is removed.  I tested the helix auger and it spins freely.  I then marked the helix auger and re-installed the dispenser bucket.  I depressed the lever on the door and the motor ran.  I then pulled the bucket out and looked for my mark on the helix auger.  The mark had not moved so it seems the helix auger inside the bucket is not moving.  So, if the metal drive auger on the motor is spinning but the helix auger in the bucket is not spinning, what could be wrong?  Could it be the drive cup?  Thanks.
Does the dispenser door open?
First make sure the helix auger turns freely by hand.
Next check the auger drive on the auger motor. Although it may turn when you engage the motor, it may not be sufficiently attached to the motor to turn when any weight is applied.
Try tightening the drive by rotating it on the shaft ( I think in the same direction it turns when the motor is engaged). If it continues to come loose then either the drive (more likely) or the shaft (less likely) is stripped.
Edited by DurhamAppliance
The dispenser door does open.  The helix auger does spin freely.  I removed all of the ice from the bucket, re-installed it, and then tested the helix auger using the motor and it did not move.  It had no resistance from any ice.  I will try tightening the drive tonight after work as you suggested and let you know.  Thanks for the replies.
Sho' Nuff Chozin, you were right on.  The auger drive is just spinning on the shaft.  I tried to tighten as you suggested but it will not tighten.  There are threads on the shaft that would indicate there may have been a nut to tighten down the auger drive to the shaft.  Is there supposed to be a nut?  I was able to find a parts diagram for a similar ice maker and it shows some sort of nut (nut J) the appears to go between the auger drive and the motor, not on top of the auger drive.  Not sure how that would work.  Any information on tightening the auger drive would be appreciated.  Thanks.
The auger drive was stripped so I bought a left handed nut to tighten down on the auger drive.  The unit is now working.  Thanks for the help.
Great find! The drive suppose to tighten itself and a nut is not provided. I've tried finding nuts for this but with no luck. I actually took the auger into home depot but they could not find the right size. Do you remember the size you purchased? If it loosens again, you may need a lock nut/washer or some locktite.
Yes, it was a 5/16" x 18 left handed nut I found at my local hardware store in New Orleans.  I fixed it for 75 cents.  If it loosens I may use the lock washer or tack weld the nut to the auger drive.  Again, I appreciate your help in the diagnosis.  Another store in New Orleans had the nut, the name was Fastners, Inc.
Followers 0
