Learn how to be your own tech line...
applianceman97
Frigidaire double wall oven bake element wont work
3 posts in this topic
Frigidaire double wall oven. Model # PLEB27T8CCB. Bake element in upper oven will not work. Broil element works okay. Could not get control panel apart to do further testing. (someone already stripped the screw heads.)  I know this model has 2 relay boards. one for the upper and one for the lower oven. Im assuming its the relay board. After looking at the diagram it shows a it show a thermal circuit breaker on the upper and lower oven. I havent seen this exact wording in a wiring diagram before. But with the broil element working that would mean thats not the problem. Any other thoughts besides the Relay board?
Edited by applianceman97
If the element is good I'm thinking a relay board too. With these ovens every time I've had a realy board be at fault for no bake its been a burned solder joint on the board. I always repair the board to keep costs down and then I don't have to pull the oven out a second time to replace the board after ordering one. I can charge more in labor for repairing the board so its a more profitable job then replacing the board. Your method may vary but thats what I do if the board is fixable with a soldering gun.
While the oven is out pull the cover off the junction box and make sure the wire nuts are tight and not burned. 10% of the time with a burned joint on a board there is a half melted wire nut too.
Edited by -Mike-
Thanks for the info Mike! I will check all that! Thought I was thinking the right thing. Good to hear it from another source. I haven't seen this exact model before. I don't work on many wall ovens.
