VTXRIDER
LG ER FF Code
9 posts in this topic
Forum readers,
Brand New to the site forgive me if I miss any forum etiquette. I did read a few post related to my problem and they helped. As a matter of fact it help me replace the freezer fan motor in my LG LRSC 26925TT side by side. Unfortunately it did not solve the problem. I did NO software updates or mother board replacement just the freezer fan motor. It still gives me the er ff code after a plug in. There is  also no ice build up and the unit has been down for a week. Are there any simple test or is it evident the tandem parts need replacing as well.
:thanks:  for any help
The Dean explains the pitfalls with this repair in detail here.
Basically make sure you installed the upgraded evap fan:  http://www.repairclinic.com/PartDetail/Evaporator-Fan-Motor/4681JB1029A/1330410
Note the part number in the linked fan and compare with the one you replaced.
Not sure if the muthaboard in this model has been upgraded or not:  http://www.repairclinic.com/PartDetail/Main-Control-Board/EBR58010501/1472874
We'll sit tight and wait for the Dean to guide us.
No service bulletin concerning Main PCB although I suspect that's the booger.  Evap fan motor has been upgraded.
1 person likes this
Depends on the Serial Number...
LG has been struggling with moisture contamination/damage in their refrigerators for some years now.
As of this posting---it *appears* that they're finally getting a handle on it.
For the LRSC26925 models---if the Serial Number is:
603MRXXX through 812MRXXX (Mar 2006 - December 2008)...
The MAIN BOARD was changed from (6871JB1929Y) to the revised/corrected part number (EBR58010501).
This corrected *overcooling* complaints.
LG servicers were also instructed to visually inspect the THERMISTORs in both---the Freezer and Refrigerator compartments---for "partially-buried" Thermistors (inside the blow-injected foam insulation).
Any Thermistor found "stuck" in the cured insulation---is to be pulled out and re-attached to the Thermistor Case/Cover (for accurate temperature sensing).
If the Serial Number is:
906MRxxx or older...
Both Door Gaskets were re-designed---to improve sealing (moisture control).
Freezer Door Gasket (4987JJ1010L)
Refrigerator Door Gasket (4987JJ1010M)
In your particular case---the Evaporator Fan Motor likely failed due to moisture contamination---shorting out the tiny intergrated-circuit inside the Fan Motor Housing.
Which then---damaged the Main Board.
Replace both.
Evaporator/Freezer Fan Motor (4681JB1029A)
Main Board (EBR58010501)
Other possibles---though less likely...
Damaged wiring in freezer door hinge (top of door)
Failing/failed Door Switch
1 person likes this
Thanks  very much for all  the help. Works very much like my motorcycle boards every one willing to lend a hand, much appreciated.
I checked the serial number and my unit is an 2005 (502KRLR00152) bought in Jan 2006. I will try the main board if the cost does not out weigh the remaining life of the unit. I have replaced the freezer fan motor behind the ice maker.
I am assuming the thermistors can be checked with a meter? Where can I find a schematic on here to locate these parts on this unit?
I have been getting my LG parts from S**rs. For me the consumer they have been excellent in shipping and customer service and pricing have been excellent.
<<<I am assuming the thermistors can be checked with a meter?>>>
No need to test the THERMISTORS---just pluck 'em out from the insulation---and attach them to the small white plastic "cage" (which can be seen in both compartments).
<<<Works very much like my motorcycle boards every one willing to lend a hand, much appreciated.>>>
<<<I have been getting my LG parts from S**rs. For me the consumer they have been excellent in shipping and customer service and pricing have been excellent.>>>
Sears does not "lend a hand" like that motorcycle forum does---and their return policy is woefully lacking compared to RepairClinic:)
Especially when it comes to electronics.
1 person likes this
I was unaware of the "repair clinic" checking them out now! Thanks :thumbsup:
Much more knowledge in a short time . I will try the main control board next. It looks very easy to replace and somewhat cheaper than a new unit. I will also clean the coils and evaporator fan area which I may have been one of the millions to neglect this area for maintenance.
