GE single oven and Wolf Dual Fuel Range
1 reply to this topic
#1 Tim
Tim
  • 1 posts
Posted 09 May 2005 - 03:13 AM
I am wiring both a 30" GE wall oven (ZET938SFSS) and a 36" Wolf Dual Fuel electric oven (DF364C) to a single 50-amp branch circuit.  (1) Code says it's OK, I'm tapping a #6 using #10 (30A) for each oven - comments? (2) The house was built in '58 and the existing #6 branch circuit I'd like to tap has 2 hot leads and an unsheathed aluminum common.  If I use Al-Cu wire nuts is this OK, or should I replace the branch wire with new #6 Cu wire?
  • 24,321 posts
Posted 09 May 2005 - 04:08 AM
What code says this is ok?  Not the NEC-- #10 is too small for a range, the minimum gage is #8 for a 40 amp circuit.  More information here.
Copper wire is always preferable to aluminum so, if you have a choice, go copper.
