Frigidaire SxS PHSC239DSB2
Patricio
Does the '2007 SxS Electrolux Refrigerator with electronic control' work for this model?    I held freezer up arrow while pushing freezer down arrow 3 times.    Some of test parameters are not the same as the manual shows.   Example the evaporator fan test showed a number then next push of down FF arrow down displayed 'h' & fan went into high speed.  next push 'L' & low speed.   Thermistors did not flash only shoed letters.
Complaint was fan making loud whirling noise & freezer temp rose to 27 degrees. Turned out to be ice fell in fan & was almost completely disenigrated, & evaporator just came out of a defrost cycle.   Client called, I was 4 blocks down so I arrived within 30 minutes of being called.
If a different manual is available may I have it.   I was not able to find much info pertaining to this model.   Danke
  • Patricio
