Haier Small Wine Cellar
1 reply to this topic
#1 Guest_BookemDano_*
Guest_BookemDano_*
  • Lurking at the Threshold
Posted 09 May 2005 - 03:36 AM
Ok
My name is Dan. You may think I am nuts but here goes.
I just bought this thing. On the store display it's called a wine cellar.
Dummy me I didn't get a hint from that because I wanted it to keep beer and pop cold also.
Well beer is not very good at 46 deg f.
 I have been tinkering with the control to get it to be at a lower range but I don't know what the theory of the control is. My guess is that the control in there is not capable of the range I am asking it to be.
I can get it down to below freezing by adjusting a hidden screw on the control but then it won't shut off. Darn I thought I had it figured out and then no I don't it's a run away.
It is either 45 Degress or it win't ever shut off and could freeze everything.
 I can't find middle ground so to speak.
Can you point me in the direction of a capillary control that is spst make on rise. just a mechanical one That I could stick in there. I realize I have already voided the warranty.
Thanks in advance
  • 24,360 posts
Posted 09 May 2005 - 04:23 AM
You just need to install a cold control kit that will operate in the beer range.  The GC505 should work nicely.  You can buy it here.
