GE PSCS5RGXCFSS diagnostic guide needed
acfixerdude
There is only one document I found for PSCS5RGXCFSS and it is the wiring/sealed system schematic which I do not need. l need instructions for going through self diagnostic and specifications/tests, etc.
Some good info on these dl's, thanks. Anything specifically for the PSCS series? Everything is controlled from the dispenser.
Thanks
Thanks for the heads up on the Dropbox 404.  I'll track that down.  Turns out, it probably wouldn't have helped you anyway.  Here is the Holy Scripture for the Perverter units:  http://appliantology.org/files/file/757-ge-refrigerator-inverter-compressor-diagnostics-manual/
Awesome, Brother Durahm!  Dayyam, I had completely forgotten I uploaded that!  I'll delete the Dropbox link.
  • 3 years later...
TACO SERVICE DEPT
The top link doesn't work because the file was deleted. But the second and third links still work and they're way more useful.
Here's the same video as first link:
TACO SERVICE DEPT
this is very helpful the only problem i have now is i dont have the diagnostic testing tool the control board & the keypad are available but the harness is discontinued no longer available.  does anyone have any insight on this or can you order the plug ends & build your own??? & if yes where can you get the plug ends
Edited by TACO SERVICE DEPT
  • 1 year later...
Same problem. Would be great if someone can help.
Welcome to Appliantology, @royeradames! We’re all happy to help. This forum is for service manual requests only. For troubleshooting help, head on over to the Appliance Tech Repair Forum and post what you have going on there.
  • Thanks 1
