Whirlpool Conquest Gold Icemaker Spewing Water
28 replies to this topic
#21 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 04 January 2014 - 08:14 AM
OK, I tried the "Free Way" just to see if I could make it work. Please let me know how I did.   I was an apprentice at one time a few years ago, which I thought was for a  year, apparently now it only lasts two months?
#22 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,726 posts
Posted 04 January 2014 - 09:02 AM
The world, like its climate, is ever changing.  The only thing that stays the same yesterday, today, and forever is Jesus Christ.  Can I hear an "Amen?"
#23 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 04 January 2014 - 01:03 PM
  1. Alright then.  I finally got a response from the LED by just unplugging the fridge and plugging it back in, waiting five seconds, and voila, I got a steady light for about 5-seconds, which means the first generation optics are working.  Next up, I jumpered T and H and got the icemaker to go through a cycle.  Removed the jumper (which I made myself out of twisted pair, I'm so proud) halfway through and let it finish the rotation.  Big CLICK! at about 12:00 and then it returned to 10:00 home.  No water fill.
So, I'm pretty sure this is a water supply issue, which makes sense since it flooded my freezer.  Guess I need a new valve?  Agree?  Got parts?
Also, the ice cream is as hard as a rock.
Edited by cjhsa, 04 January 2014 - 01:05 PM.
#24 DurhamAppliance
    Sho' Nuff Chozin
  • 5,895 posts
Posted 04 January 2014 - 02:02 PM
That does not necessarily mean the ice maker is energizing the valve or your water line is clear.
As stated earlier, if your water line is clear, replace valve then icemaker or both (if ice maker is over 5 yeads old, replace it anyway) . You indicated the IM recently spit out ice. That would tend to rule out a motor problem (in most cases) as well as an optic problem.
Certified Tech is correct, that piece covers the wire connections between ice maker and fridge. It is attached by a screw on the right rear bottom of the icemaker support tray. It then wraps around the top right of the icemaker covering the exposed connections. I am not sure how you took out the icemaker without removing the screw that attaches it to the icemaker support tray.
www.DurhamApplianceThrift.com
#25 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 04 January 2014 - 02:09 PM
I figured out how that piece goes back in.  I just didn't see it fall off the first time I removed the ice maker.
#26 Samurai Appliance Repair Man
    Shōgun
  • 30,726 posts
Posted 04 January 2014 - 02:29 PM
Brother Durham speaketh much wisdom; ignore his advice at your peril.  Just to put it all together for you, you need:
Ice maker assembly:  http://www.repaircli...2198597/1016069
Water inlet valve:  http://www.repaircli...0408179/1938614
All come with a 365-day, no-hassle Return Policy:  http://www.repaircli...r/Return-Policy
#27 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 04 January 2014 - 03:48 PM
I'm not ignoring anyone!  Thanks!
#28 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 08 January 2014 - 08:26 AM
Could excess humidity in the house cause the water line to freeze up?  I found a leak in my furnace that was caused primarily by a baffle touching the humidifier pad, causing water to run into the ductwork.
#29 cjhsa
cjhsa
    Yamabushi
  • 68 posts
Posted 21 January 2014 - 11:45 AM
Just FYI, but I haven't bothered to work on this further because I had a slew of other appliance/plumbing issues happen within a two week period.  Not only did the ice maker die, a 37" HDTV bit the dust, my washing machine failed to drain, the disposal started leaking, the heater did too....and on and on.  ARGH.
