    • 30 March 2024 02:00 PM Until 03:00 PM
      If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form.
      When: Saturday, March 30 @10:00 AM Eastern Time.
samsung refrigerator question
appliance repair tech
hello, i have a samsung french door style fridge, model# RFG296HDRS  and i am wondering where the water valves are for the icemaker and water dispenser, usually they are located down in the bottom back of fridge but on this model of fridge the waterlines run in the back middle of fridge and a water line rus up to the icemaker, inside the fridge in the middle is where the water filter housing is located so the lines running to that make sense but i have the actual service manual of samsung for this model and even that does not show where they are located either by picture or by part numbers on the exploded view of internal parts, also i have been to sears web site and even with their exploded views they do not show either pictures or part numbers for this valve, so is there any samsung techs out there that would know the answer to this?
        thank you.
Link to comment
Valve is in the filter housing.  Isn't that a perfectly intuitive place ot put it?   :teehee:
There's a service bulletin that shows this, may shed some light:  http://appliantology.org/files/file/1517-samsung-refrigerator-service-bulletin-water-leak-at-the-icemaker-or-the-water-dispenser-dispensing-on-its-own/
  • Thanks 1
Link to comment
  • 5 years later...
Bintiwangu
On 1/3/2014 at 3:56 PM, Samurai Appliance Repair Man said:
 Thank you Samurai, it does indeed shed light on it. Nice photograph right when I need it!
Link to comment
