24 volt tester
24Volt
6 replies to this topic
#1 Patricio
Patricio
    Opa
  • 1,603 posts
  • Flavorite Brew:Home brewed ice tea
Posted 05 January 2014 - 07:15 PM
I needed to test a contacter in a heat pump compressor & I wanted a live test so a made a jumper out of an old 120/24 volt transformer.  Alligator clips on low voltage side & 120v plug on high voltage side.   Tells me for sure if contacter snaps in & is good so I can elimnate it as a problem.   Will work for other situations that calls for 24v.
Former Student of Master Samurai Tech School.   Current Student of  Master Samurai Tech School
http://www.mastersam...iliate.php?id=5
#2 acfixerdude
acfixerdude
    Sōhei
  • 243 posts
  • Flavorite Brew:Lagunitas IPA
Posted 06 January 2014 - 04:26 AM
I might have to find an old transformer laying around in the basement and make me one of those to test PCB relays...
Visit LBKappliance.com for service in the Lubbock, TX area!
#3 BryanS
BryanS
  • 1,777 posts
Posted 06 January 2014 - 03:33 PM
First off, all you have to do is push the plastic button on the contactor to engage it. I usually use my multimeter lead or leads to push it in. Check from one side of the 24v coil to the other side for 24v. If you have 24v to the contactor coil, the compressor and condensor fan kick on when you manually push in the contactor, then it's safe to say your contactor is bad. I've had a few contactors that were energized but voltage wasnt going through because the contacts were to pitted. Then you replace it. You can rig up a tester if you want, but I don't see the need for it for an a/c contactor.
Edited by BryanS, 06 January 2014 - 03:34 PM.
#4 acfixerdude
acfixerdude
    Sōhei
  • 243 posts
Posted 06 January 2014 - 05:20 PM
I think he may be referring to testing when he doesn't have 24v going the coil. I've known a bad coil to take out a new T-Stat or fan board.
#5 wishfultech
wishfultech
    Yamabushi
  • 79 posts
  • Flavorite Brew:iced tea
Posted 07 January 2014 - 06:09 PM
I built 1 of those several years ago and it does come in handy for checking things. At the time I built it I was looking for a solution for checking controls with the high voltage off.Works like a charm.
#6 acfixerdude
acfixerdude
    Sōhei
  • 243 posts
Posted 13 January 2014 - 01:31 AM
Did you output 24v DC or AC?
#7 wishfultech
wishfultech
    Yamabushi
  • 79 posts
Posted 14 January 2014 - 08:08 PM
24 V AC
