Whirlpool gz25fsrxyy2 Ice Maker Problems
ApplianceMagic
I can't get the dang thing out.  I see the plastic clip on the side and with it out of the way I still cannot pull the plastic housing (underneath) out.  I even got the ice maker itself out but still can't see what is holding the plastic part it.  A manual would be good.  Thanks.
This is like the Maytag Iceland models.  This file will show you how to remove it:  http://appliantology.org/files/file/1091-whirlpool-modular-icemakers-in-cubby-in-the-ff-compt-in-french-door-refrigerators/
Once you get the harness unclipped and start pulling the icemaker out, the fill spout will catch on the icemaker.  Just pull harder.  The fill spout is rubber and will give.
Thanks!
