Kenmore 70 series Dyer Issue model 110.76722695
Kenmore Gas Dryer button
5 replies to this topic
#1 jstatham
jstatham
  • 1 posts
  • Flavorite Brew:water
Posted 07 January 2014 - 08:27 PM
I have the Kenmore Gas Dryer Model 110.76722695 that will sometime only run if the start button is held down.  This only happens sometimes but when it does I tape down the button and it drys fine. What do I need to test?  I have read several places that it could be the motor but I just replaced it less than 6 month ago. Is it the actual start button? Any help and direction will be greatly appreciated.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 January 2014 - 09:54 PM
I can't find the tech sheet for that model,
unless you have one you could scan & upload somewhere
#3 Scottthewolf
Scottthewolf
    Senpai
  • 2,953 posts
Posted 07 January 2014 - 11:26 PM
Could be a bad push to start switch, also could be a motor. Since the push to start switch is under $20 it's worth a try before you waste time and money on another new motor.
Link to new push to start switch: http://www.repaircli.../3395385/526865
Scott Wolf
#4 fairbank56
fairbank56
  • 1,103 posts
Posted 07 January 2014 - 11:47 PM
  It's not the start switch. The switch is only momentary contact and yours is working. The problem is either the motor switch or the wiring to it. When you press the start button, the motor starts, closing the centrifugal switch which then parallels the start button so that the dryer remains running when you release the button..
Eric
#5 Scottthewolf
Scottthewolf
    Senpai
  • 2,953 posts
Posted 08 January 2014 - 12:06 AM
Yeah, Eric, you're right. I haven't had that failure happen in a long time.
Scott Wolf
    Shōgun
  • Master Samurai Tech
  • 30,526 posts
Posted 08 January 2014 - 10:16 AM
Replacement motor: Part number: AP3094245
