Milanomike
GE Over the Range Microwave (JVM1840DWW)
8 posts in this topic
Hi,
I've been searching around and can't find much on this one.  My over the range microwave surface light bulb burned out a few weeks back.  No big deal, over to Lowes, a new 40 watt bulb and 4 bucks later, done.  That bulb lasted about a month.
OK, maybe it wasn't quite the right bulb, over to the appliance parts place and they have a GE brand bulb for 15 beans and an aftermarket one for 7 beans, these guys are generally good, so I take the 7 buck one and off I  go (as I know the GE one is junk anyhow).  The guy warned that there could be a problem with this unit.  Well that bulb lasted 4 days.
Anyone seen this before?  Microwave makes microwaves, and fan works on both speeds, sure is annoying with no light.
As always, any tips are appreciated.
Mike
Is that the screw base bulb?I use a Satco 130 Volt version of it and they last longer.
Yes, it is a screw base bulb, small base I think.  Searching around I don't see this anywhere.
I have not taken anything apart, but the entire bulb holder/fixture seems pretty flimsy.  Thinking I'll at least stick my meter in there and see what voltage this thing is sending to that socket, maybe that will provide a hint.  Will see what I can learn.  Thanks for the input.
OK, it was a 130 volt, 40 watt bulb that lasted 4 days, something is messed up here.
Hi,
Originally put this in the small appliance forum, but realized these seem to be covered in the kitchen appliance forum, sorry for what might be a double post.
Anyone seen this before?  Microwave makes microwaves, and fan works on both speeds, sure is annoying with no light.  My latest bulb was a 130 volt bulb, seems like something is wrong with the unit somewhere.
Mike
Did you try replacing it with the OEM bulb for this model?  http://www.repairclinic.com/PartDetail/Light-Bulb/WB36X10003/259682
Comes with a 365-day, no-hassle Return Policy:  http://www.repairclinic.com/Layer/Return-Policy
How-to video on the part link page gives tips for installation.
Well, I used the OEM replacement bulb, not the GE branded bulb from the local appliance parts place (not a HD/Lowes, just appliance parts), we looked up the p/n (WB36X10003) from my GE microwave manual.  The bulb looked identical to the original bulb (not the Lowes bulb) and was a 130 volt bulb.  I can check to see if there is a brand name on it. Are you suggesting that I should purchase the official GE branded bulb, I'm somewhat skeptical as I doubt GE makes the bulb these days.  Thanks for input.
I can pretty much guarantee you that GE does NOT make the bulb.  But the actual manufacturer is unimportant.  What is important is the bulb SPECIFICATIONS.  And I can guarantee you that GE wrote the specifications for the bulb and the contracted supplier is manufacturing them to those specifications (or attempting to within statistical process control variations).
