Robyn Kirsch
Kenmore HE2 washer leaking from dispenser 110.46502700
6 posts in this topic
When I start a load my washer leaks out the soap dispenser. I have taken the top off and removed the "mushroom" accordion hose between the drum and the dispenser. It was not clogged at all and barely even slimy. Please help! I have 5 kids and cannot go without laundry.
the hose you see under the top is not wear the water goes in, the hose the water flows thru is on the front of the tub, pull the boot back at the 10 O,Clock position and look for a sock stuck there
I agree with sh2x2. likely a garment caught where water enters drum at the end of the mushroom accordion thingy. Very common problem.
I took out approx 20 bolts & torch screws to get to the other hose coming from the dispenser (underneath it, so I had to remove the dispenser, half the stuff holding the dispenser and the front cover on) to find a sock stuck in the drum end of the hose. Problem solved :)
Good job you :thumbsup:.That's $100.plus in your pocket.
Wow, you guys freakin' called that.
