Kenmore washer 417.44152400
Patricio
May I have a service manual for this Frigidaire made for Kenmore Front load washer.  Complaint is no spin.
  • Patricio
Thank you.  went & used a couple of manuals from previous posts that was not the same model number. an affinity manual & a 3 cu ft manual & a samurai video.  Unplug & door opens immediately.   Figured out fault code from blinking LED's again thanks to Samurai (4 door latch) 7 put into diagnostic mode everything good, pump moves water out.    Therefore it must be a defective door latch.    Not on my truck, part will be ordered.
