Bucspurgiant
Kenmore dishwasher not draining during cycle
8 posts in this topic
I replaced the impeller a month ago to repair the leak. I took the dishwasher out of the space to do it. Now my dishwasher will not drain during the cycle. I have to press cancel about five minutes later to drain the dishwasher. I was convinced the problem was the control board so I replaced it. Now the wash interval seems to be shorter and it still won't drain. I hear clicking sounds as if a signal is sent. I checked the drain valve for blockage. What am I missing?
What am I missing?
A model number.
Sorry. That would help. Wouldn't it?
66515958790
That was the last thing I did before posting this. It was clean but I ran water throughout it anyway. The water is only supposed to flow one way. Right?
If it does drain, just so slow you have to press the cancel button 5 times thats got to be one of two things. The most common by far is something is restricting the drain line somewhere. If thats not it you may have an impeller in the drain pump that has been damaged. Like if a piece of glass was in there and wore down or broke off some of the vanes.
If  the drain hose connects to an air gap on top of the sink take that apart and look  for something blocking the water flow. Like a big ball of gunk or anything else that could have made its way through the drain line. If its clean, disconnect the drain hose from the air gap and see if the dishwasher will drain in to a bucket. You may have something floating around in the drain hose thats too big to fit through the air gap so by draining it in to a bucket that should clear the object out if there is something in there. If it connects right to the disposer of sink drain disconnect the hose there and make sure nothing there  is blocking it. Its very common  for the connection on the disposer to plug up with disposer junk.
Does this have the factory plastic drain hose on it or is it connected to a rubber hose? Those rubber hoses will kink over time and stop the water flow.
As Mike said, you most likely kinked the drain line when you pulled it out and then reinstalled the dishwasher.
I removed the drain hose (it is the manufacturer version) and sprayed water through it with a garden hose. It took the housing apart to check on the impeller. I did not see any obstructions. I am running it again. I still don't understand why the intervals or so short. The wash cycle only lasts about 20 seconds. That is why I thought the problem was electrical.
