  • Announcements
Level2Learning
Viking range VGSC3666BBU Runaway Bake Cycle
3 posts in this topic
So this RED Viking range starts heating on bake, and doesn't stop.  Even when I turn it off!  Any ideas from the members?  I was going for DSI board...
Hey, Rich, it sounds like the PM010129 relay (behind the access panel below the door) is stuck. There have been a few different versions so I have uploaded the bulletin showing the wiring on all 3 along with the wiring diagram for the whole range. I also uploaded a bulletin pertaining to an issue that the preheat board may cause. It calls for a jumper wire but you can just remove the 2 wires from the relay on the board and connect them to each other and achieve the same result.
Wiring Diagram:  http://appliantology.org/files/file/1559-viking-vdsc367-36-inch-range-wiring-diagram/
Bulletin: Replacement Relay:  http://appliantology.org/files/file/1558-viking-technical-bulletin-replacement-pm010129-relay/
Bulletin:  Cycling Relay Failure:  http://appliantology.org/files/file/1557-viking-range-service-bulletin-cycle-relay-failure/
Part number: AP5317437
All of these bulletins don't mention the model I have? Would it be the same?
The customer is away and back next week...
